Bass Guitar Kits
Our bass guitar kits let you build a full-scale, giggable bass from scratch. We carry J-style, P-style, and several other bass body shapes, all with proper long-scale necks, quality tuning machines, and bass-specific pickups and electronics.
Bass kits are a great first build. The parts are larger and easier to handle than guitar components, the wiring is simpler on most models, and the results are immediately satisfying. You will have a bass that thumps and growls exactly the way you set it up.
Every bass kit includes a pre-shaped body, a fretted neck, bridge, tuning machines, pickups, pots, jack, and all mounting hardware. We use hardwoods like mahogany, ash, and basswood for the bodies, and maple for the necks. The fretwork is done, so your job is the finish, wiring, and final setup. Whether you play fingerstyle, slap, or pick, there is a bass kit here that fits your sound.
Filters
Original price $269.99 USD
Current price $219.99 USD
$219.99 USD - $219.99 USD
Skill 9/10 Advanced
Block-Inlay Slingback Offset Bass Guitar Kit with Paddle Headstock, Mahogany Body, Maple Fretboard, 2 Single-Coil Pickups
Original price $249.99 USD
Current price $224.99 USD
$224.99 USD - $224.99 USD
Skill 3/10 Beginner
What Makes This Kit Different Black block inlays set into a pale maple fretboard. Every marker on this neck is a solid black square, from the first...
Left Hand JM Bass Build Kit with Mahogany Body and Ebony Fretboard
Current price $254.99 USD
$254.99 USD - $254.99 USD
Skill 3/10 Beginner
A left-handed JM-style bass kit featuring a solid mahogany body with spalted maple veneer and a smooth ebony fretboard. The bolt-on maple neck with...
34-Inch 5-String EXP Bass Style Guitar Kit Mahogany Body, Flame Maple Veneer
Original price $319.99 USD
Current price $259.99 USD
$259.99 USD - $259.99 USD
Skill 5/10 Intermediate
Build your own professional grade 34 inch 5 string EXP style bass guitar with this mahogany body DIY kit. Designed for players who want aggressive ...
Headless 4-String Bass Guitar Kit, 34 Inch Scale, Mahogany Body, Maple Neck, Rosewood Fretboard
Original price $259.99 USD
$259.99 USD
Full Specifications General Dexterity: Right-Handed Number of Strings: 4 Size: Full Size Build Difficulty: Intermediate (5/10) Fixed bridge ...
WB Bass Guitar Kit with Mahogany Body Flame Maple Top, Rosewood Fretboard
Current price $269.99 USD
$269.99 USD - $269.99 USD
Build your own DIY bass guitar with a beautiful flame maple veneer mahogany body, and trapezoid pearl white inlays on a maple neck with a skunk str...
5-String Thrash Bass Kit with Mahogany Body
Build your own Thrash-style bass with mahogany body and maple fretboard using our DIY guitar kits. Full Specifications General Dexterity: Right-Ha...
Basswood Violin Bass Kit with Pau Ferro Fretboard
Skill 8/10 Advanced
Experience the joy of creating your own music with our DIY Violin Bass Guitar kit! This short-scale (30" / 760 mm) kit includes all the materials n...
WR Mahogany Bass Kit with Rosewood Fretboard
Skill 3/10 Beginner
Full Specifications General Dexterity: Right-Handed Number of Strings: 4 Size: Full Size Build Difficulty: Beginner (3/10) Bolt-on neck join...
WB Bass Guitar Kit with Flame Maple Top, Maple Fretboard
Current price $279.99 USD
$279.99 USD - $279.99 USD
Skill 8/10 Advanced
Build your own DIY bass guitar with a beautiful flame maple veneer, and a maple fretboard and neck with a skunk stripe. Full Specifications General...
Mahogany body R41 Electric Bass Kit with Rosewood Fretboard
Skill 6/10 Intermediate
Build your own Mahogany body R41 Bass Guitar with Rosewood Fretboard using this DIY Guitar kits. Full Specifications General Dexterity: Right-Hand...
Skill 2/10 Beginner
Build a 34-inch offset bass from a box of parts. This DIY kit gives you a solid mahogany body, a bolt-on maple neck with a 20-fret fretboard and pe...
WR Mahogany Bass Kit with Ebony Fretboard
Current price $289.99 USD
$289.99 USD - $289.99 USD
Skill 2/10 Beginner
Build and customize your own bass with the W2 Mahogany Bass Kit. This kit is designed for players who want a standout body shape, strong low-end to...
Build your own Basswood T-style Bass Guitar Kit with Maple Neck and Skunk Stripe using this DIY Guitar kits. Full Specifications General Dexterity...
34-Inch 4-String JM Bass Electric Kit
$289.99 USD
Skill 2/10 Beginner
Build your own bass with this JM-style DIY kit, featuring a solid mahogany body for rich, balanced tone and a smooth rosewood fretboard for comfort...
Lefty Basswood EXP-style Bass Kit with Maple Neck
$299.99 USD
$299.99 USD - $299.99 USD
Current price $299.99 USD
Skill 2/10 Beginner
Build your own Lefty Basswood body EXP-style Bass Kit with Maple Neck using our DIY Guitar kits. Full Specifications General Dexterity: Left-Hande...
JM Bass Guitar Kit
$449.99 USD
$449.99 USD - $449.99 USD
Current price $449.99 USD
Skill ?/10 Varies
Our JM Bass guitar kit is a solid body bass DIY kit that you can modify to your playing style and preferred musical genres such as funk, disco, reg...
MM Bass Guitar Kit
$449.99 USD
Skill ?/10 Varies
Build your own MM style DIY custom bass. Description Body type: Solid Neck Shape: C-shaped Fret Wire: Copper-Nickel Alloy Fret Size: Medi...
WB Bass Guitar Kit
$449.99 USD
Skill ?/10 Varies
Build your own custom W Bass guitar customizing body material, neck, hand-orientation, and more for your taste and playing style. Description Body...
Violin Bass Kit
$449.99 USD
Skill ?/10 Varies
Build your own Violin Bass with this DIY kit! Description Body Type: Hollow Body Sound Holes: None Internal Support: Bridge block Neck S...
Pickup Style
J-style pickups deliver a bright, articulate tone with hum-canceling in both-on position, while P-style split-coil pickups produce a fatter, punchier midrange.
Scale Length
Most of our bass kits use a standard 34 inch long scale, which provides solid string tension and full low-end response across all four strings.
Number of Strings
We carry four-string and five-string bass kits. Five-string builds add a low B for extended range but require a wider neck and adjusted nut spacing.
Body Wood
Ash bodies tend to be brighter with more high-end detail, while mahogany and basswood bodies lean warmer with rounder lows.
Are bass guitar kits harder to build than guitar kits?
Not at all. Bass kits are actually easier for many builders because the parts are bigger and easier to handle. The wiring is typically simpler too, with fewer pickup switching options.
What is the difference between J-style and P-style bass kits?
J-style bass kits use two single-coil pickups for a bright, scooped sound with lots of clarity. P-style kits use a single split-coil pickup that delivers a thicker, more aggressive midrange tone.
Can I use flatwound strings on a bass kit?
Yes. The nut and bridge on our bass kits accommodate both roundwound and flatwound strings. Flatwounds give you a smoother, more vintage tone with less finger noise.
Do bass kits come with a 34 inch scale neck?
Most of our bass kits use the standard 34 inch long scale. Check the individual product listing to confirm scale length, as a few models may differ.
370+ Video Tutorials
