Flamed Maple Veneer 34-Inch 5-String EXP Bass Style Guitar Kit, Mahogany Body
SKU EXPB-RMOB-1
Original price $304 USD
Original price $304 USD - Original price $304 USD
Current price $274 USD
$274 USD - $274 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Dec 5 – Dec 19 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Build your own professional grade 34 inch 5 string EXP style bass guitar with this mahogany body DIY kit. Designed for players who want aggressive styling and balanced low end performance, this kit includes a solid mahogany body, a bolt on mahogany neck, and a Rosewood fretboard with white pearloid trapezoid inlays. The 22 fret, 34 inch scale setup delivers familiar feel and extended range tuning stability ideal for rock, metal, and modern bass tones.
  • Number of Strings: 5
  • Flamed maple veneer is thin and easy to sand through, so use a light touch at the edges
  • Scale Length: 864 mm / 34"
  • Radius: 12" / 305 mm
  • Shape: Edge
  • Nut: Black Plastic (ABS)
  • Nut Width: 45 mm
  • Neck Pickup: P90
  • Bridge Pickup: P90
  • Controls: 2 Volume, 1 Tone
  • Bridge: Bass Bridge
  • Angular-style bass body with flamed maple top (unfinished)
  • Bass neck with rosewood fretboard and white pearloid trapezoid inlays (unfinished)
  • 5x black bass tuners with bushings and washers
  • 2x black soapbar bass pickups
  • Black 5-string bass bridge
  • Black neck plate with mounting screws
  • Black oval rear control cavity cover
  • Wiring harness with potentiometers and black knobs
  • Black truss rod cover
  • Pickup mounting springs and screws
  • Set of bass strings
Flamed Maple Veneer 34-Inch 5-String EXP Bass Style Guitar Kit, Mahogany Body is in stock.
Find the diagram for your kit
Is the top solid flamed maple?
No. The top is a thin flamed maple veneer glued onto the body. Sand it lightly so you do not sand through it.
