7-string Mahogany JBM-style Guitar with Maple Neck and Rosewood Fretboard
SKU JBM7-RMFB-4203
$289 USD
$289 USD - $289 USD
Current price $289 USD
Build your own 7-string Mahogany JBM-style Guitar with Mahogany Neck and Rosewood Fretboard using our DIY Guitar Kit.
  • Number of Strings: 7
  • Seven strings mean a wider neck and one more string to set up and intonate than a standard 6-string build
  • Number of Frets: 24
  • Shape: Styled
  • Nut: Black Locking Nut
  • Controls: 1 Volume, 2 Tone, 3-Way Toggle
  • Bridge: Locking Tremolo
  • Finish: Black Finish
  • Mahogany 7-string guitar body with quilted maple veneer (unfinished)
  • Mahogany neck with rosewood fretboard and white pearloid trapezoid inlays (unfinished)
  • 2x black humbucker pickups
  • Black rear cavity covers
  • Allen wrenches
7-string Mahogany JBM-style Guitar with Maple Neck and Rosewood Fretboard is in stock.
It has a locking tremolo with an arm. The strings clamp down at the bridge and at a locking nut at the top of the neck.
