SKU BLK-TL-L
Original price $249.99 USD
Build a custom electric guitar from the ground up with this left handed blank TE-style guitar kit, designed specifically for left handed players and builders. This unfinished slab body guitar kit is ideal for those who want full control over shaping, finishing, electronics, and final setup. The kit arrives ready for sanding, routing, carving, and customization, making it suitable for experienced builders and advanced DIY projects.
  • Dexterity: Left-Handed
  • Scale Length: 25.5″
  • Bridge Pickup: TE-Style
  • Bridge: Hardtail
  • Unfinished body blank, squared off and routed on the front for the neck, both pickups and the controls
  • 1x bag of assorted screws
  • 1x Allen wrench
