Ash 7-string JS-style guitar kit with Flame Maple Veneer
SKU JS7-RSEB-257
Original price $299 USD
$299 USD
$299 USD - $299 USD
Current price $299 USD
Featuring a right-handed, maple bolt-on neck, and a flame maple top on a solid ash body, you'll not only satisfy your inner craftsman, but you'll also have a finely-tuned instrument, ready to fill the garage with some sweet, sweet music!
  • Number of Strings: 7
  • Material: Ash (1 pc)
  • Bridge: Adjustable Bridge + String-Through Body
  • Ash guitar body with flame maple veneer top (unfinished)
  • Guitar neck with dark fretboard and pearloid inlays
  • Black bridge with seven saddles
  • 2x black bridge posts with bushings
  • Pre-wired harness with potentiometer, 3-way toggle switch and colored wire
  • Black dome knob
  • Black teardrop jack plate with output jack
  • Assorted black screws
Unfortunately, Ash 7-string JS-style guitar kit with Flame Maple Veneer is out of stock.
