Hollow Body Archtop Electric Guitar Kit, Basswood Body, Rosewood Fretboard, Chrome Hardware
SKU L5-RBRC-1
$299.99 USD
$299.99 USD - $299.99 USD
Current price $299.99 USD
Build your own Hollow Archtop Body Guitar with Rosewood Fretboard using our DIY Guitar kits.
  • Mahogany Plywood has open grain that needs filling before finishing for a smooth result
  • Material: Mahogany Plywood
  • Internal Support: Bridge block, Basswood
  • Binding: Multi-ply, Ivory
  • Scale Length: 24.75″ / 628 mm
  • Inlay Material: Abalone
  • Bridge: Vibrato Tailpiece
  • Neck with fretted dark fingerboard and green abalone block inlays
  • 2x black-covered humbucker pickups in black mounting rings
  • Chrome tune-o-matic style bridge with six adjustable saddles
  • 2x chrome bridge posts with thumbwheels
  • Chrome hinged vibrato tailpiece with arm, tension spring and mounting screws
  • Pre-wired harness with four potentiometers and red, yellow and black hookup wire
  • Box-style 3-way toggle switch with black tip and chrome mounting plate
  • 4x chrome dome knobs
  • Output jack with nut and washer
  • Black triangular jack plate
  • Assorted chrome mounting screws and washers
  • Red felt washer
Unfortunately, Hollow Body Archtop Electric Guitar Kit, Basswood Body, Rosewood Fretboard, Chrome Hardware is out of stock.
