Hollow Body Archtop Electric Guitar Kit, Mahogany Body, Ebony Fretboard, Chrome Hardware
SKU L5-RMEC-2
Original price $319.99 USD
Current price $299.99 USD
$299.99 USD - $299.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Oct 7 – Oct 21 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Build your own Hollow Archtop Body Guitar with Ebony Fretboard using our DIY Guitar Kits.
  • Material: Laminated Plywood (Top, Back & Sides) with Solid Mahogany Center Block
  • Top Veneer: Quilted Maple
  • Material: Ebony
  • Inlay Shape: Diamond
  • Bridge Pickup: None
  • Bridge: Floating archtop bridge with a trapeze tailpiece
  • Knobs: Black Plastic
  • Neck with fretted black fingerboard and split-block pearl inlays
  • Chrome tune-o-matic style bridge on a dark wooden base
  • Output jack
  • Black triangular jack plate
Hollow Body Archtop Electric Guitar Kit, Mahogany Body, Ebony Fretboard, Chrome Hardware is in stock.
1 humbucker, 1 volume, 1 tone
