Hollow Body Archtop Electric Guitar Kit, Venetian Cutaway, Spalted Maple Veneer, Ebonized Fretboard
SKU L5-RPEC-798
Original price $309 USD
Original price $309 USD - Original price $309 USD
Current price $299 USD
$299 USD - $299 USD
Build your own Hollow Body Venetian Cutaway Guitar Kit with Ebonized Fretboard and Spalted Maple Veneer using our DIY Guitar kits.
  • Material: Laminated Maple
  • Cutaway: Single (Venetian)
  • Binding: Multi-ply Ivory
  • Upper Bout: 310 mm
  • Waist: 250 mm
  • Lower Bout: 415 mm
  • Depth: 83 mm
  • Inlay Shape: Fangs
  • Shape: Semi-styled, 3+3
  • Nut: Black Plastic
  • Hollow archtop guitar body with a single rounded cutaway, spalted figured top veneer, two f-holes and multi-ply ivory body binding, routed for two humbuckers (unfinished)
  • Neck with dark fretboard and abalone pearloid fang inlays
  • 6x chrome sealed tuners with metal buttons, bushings, washers and mounting screws
  • 2x humbucker pickups with chrome covers in black mounting rings
  • Black bridge with six adjustable saddles, plus two chrome posts and thumbwheels
  • Chrome hinged vibrato tailpiece with spring, arm and black insert plate
  • Pre-wired potentiometers and 3-way toggle switch with a cloth-covered wiring loom
  • 4x black knurled knobs
  • Black round switch washer
  • Coiled string set
  • Assorted screws, nuts and washers
Hollow Body Archtop Electric Guitar Kit, Venetian Cutaway, Spalted Maple Veneer, Ebonized Fretboard is in stock.
