Double-Cutaway Contoured Electric Guitar Kit, Mahogany Body, Maple Neck, Rosewood Fretboard, 21 Frets
SKU ST-RXXA-209
Original price $239 USD
Current price $179 USD
$179 USD - $179 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Oct 26 – Nov 2 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
Build your own S-style electric guitar with this high-quality DIY guitar kit, designed for smooth playability and classic tone. Featuring a solid two-piece mahogany body and a bolt-on maple neck with a 25.5” scale length, this kit delivers balanced resonance and comfortable feel. The rosewood fretboard with a 9.5" radius and white dot inlays ensures easy fretting across all 21 frets. Equipped with three single-coil pickups, a 5-way selector, and Vintage-style tremolo bridge, this kit is perfect for builders looking for iconic tones and customization freedom.
  • Radius: 9.5" / 241 mm
  • Knobs: White
  • Neck with dark fretboard, dot position markers and a drilled headstock
  • 1x chrome vibrato arm
  • 1x bag of assorted screws
Double-Cutaway Contoured Electric Guitar Kit, Mahogany Body, Maple Neck, Rosewood Fretboard, 21 Frets is in stock.
