Double-Cutaway Contoured Electric Guitar Kit, Ash Body, Flame Maple Veneer, Humbucker + Two Single-Coils
SKU ST-RSBC-1
Original price $289 USD
Current price $239 USD
$239 USD - $239 USD
Ash body ST style guitar kit with Flame Maple Veneer, Maple Skunk Stripe Neck.
  • Material: Ash (2-3 pc)
  • Binding: Black
  • Binding: Black
  • Pickguard: Pearl White
  • Knobs: White
  • Cavity Covers: White
  • Guitar neck with dark fretboard and white dot inlays
  • White pearl pickguard fitted with two white single-coil pickups, one white humbucker, three white skirted knobs and a blade switch with white tip
  • 6x chrome sealed tuners
  • 6x chrome tuner bushings
  • 6x chrome washers
  • Set of guitar strings
  • White translucent tremolo cavity cover plate
  • Chrome neck plate
  • Black neck plate gasket
  • 4x neck mounting screws
  • 3x tremolo springs
  • Chrome tremolo arm
  • 2x chrome strap buttons
  • 2x black-headed mounting screws
Double-Cutaway Contoured Electric Guitar Kit, Ash Body, Flame Maple Veneer, Humbucker + Two Single-Coils is in stock.
Is the top solid flamed maple?
No. The top is a thin flamed maple veneer glued onto the body. Sand it lightly so you do not sand through it.
It has a tremolo bridge with an arm. Six screws hold the front edge of the bridge to the body. Three springs in the back of the body pull against the strings.
