SKU BLK-TL-A
Original price $249.99 USD
Build a classic tone machine from the ground up with this blank TE-style guitar kit. Designed for makers who want full shaping, finishing, and tonal control, this slab-body kit arrives unfinished and ready for carving, sanding, routing, and personal customization. The maple neck paired with a rosewood fretboard delivers familiar snap and warmth, while the blank headstock gives you freedom to design your own signature shape.
  • Scale Length: 25.5″
  • Bridge Pickup: TE-Style
  • Bridge: Hardtail
  • Mahogany body blank, uncut, routed for the pickguard, control cavity and bridge
  • Neck with dark fretboard, frets and dot inlays
