F3 Guitar Kit with Quilted Maple Veneer, Ebony Fretboard
SKU FB-RMEB-1
$289.99 USD
$289.99 USD - $289.99 USD
Current price $289.99 USD
Build your own DIY guitar with a beautiful quilted maple veneer mahogany body, ebony fretboard, and black hardware.
  • Top Veneer: Quilted Maple
  • Scale Length: 628 mm
  • Material: Ebony
  • Inlay Material: Abalone
  • Guitar body with figured maple top veneer, unfinished
  • Guitar neck with dark fretboard and abalone block inlays
  • 2x black-covered humbucker pickups in mounting rings
  • Black adjustable bridge
  • 2x black bridge posts with anchors
  • Black stop bar tailpiece
  • 2x black tailpiece studs with anchors
  • Pre-wired control harness with 4 potentiometers and output jack
  • 4x black knobs with chrome caps
  • Large black pickguard
  • Black rear cavity cover
  • Set of strings
  • Assorted black screws
  • Hex nuts and washers
F3 Guitar Kit with Quilted Maple Veneer, Ebony Fretboard is in stock.
2 mini humbuckers, 2 volume, 2 tone, 3-way toggle
