Double-Cutaway Contoured Electric Guitar Kit, Ash Body, Flame Maple Veneer, Humbucker + Two Single-Coils
SKU ST-RSBC-1
Current price $239.99 USD
$239.99 USD - $239.99 USD
Ash body ST style guitar kit with Flame Maple Veneer, Maple Skunk Stripe Neck.
  • Bolt-on neck joint bolts straight on, so there is no gluing or clamping to get right, but the flamed Maple veneer is thin and easy to sand through, so use a light touch at the edges
  • Material: Ash (2-3 pc)
  • Binding: Black
  • Top Veneer: Flamed Maple
  • Scale Length: 648mm / 25.5″
  • Binding: Black
  • Pickguard: Pearl White
  • Knobs: White
  • Cavity Covers: White
  • Guitar neck with dark fretboard and white dot inlays
  • White pearl pickguard fitted with two white single-coil pickups, one white humbucker, three white skirted knobs and a blade switch with white tip
  • 6x chrome sealed tuners
  • 6x chrome tuner bushings
  • 6x chrome washers
  • Set of guitar strings
  • White translucent tremolo cavity cover plate
  • Chrome neck plate
  • Black neck plate gasket
  • 4x neck mounting screws
  • 3x tremolo springs
  • Chrome tremolo arm
  • 2x chrome strap buttons
  • 2x black-headed mounting screws
Double-Cutaway Contoured Electric Guitar Kit, Ash Body, Flame Maple Veneer, Humbucker + Two Single-Coils is in stock.
