We’re thrilled to share this incredible video from our friend ABD of MixWithABD, who dives deep into the art of guitar building with one of our DIY kits. Whether you’re a beginner or a seasoned builder, this video is a treasure trove of insights, covering everything from applying a flawless Tru Oil finish and wet sanding to polishing, installing the neck, and wiring the electronics.
Part 1
Part 2
ABD’s clear and engaging approach makes the process enjoyable and inspiring, showing just how rewarding it is to craft your own instrument. Tune in to follow the journey and stay tuned for the next part in this exciting series!
Learning guitar by yourself is absolutely possible if you follow the right path. This beginner guide covers what to practice first, how to stay consistent, and how understanding your instrument can help you improve faster.
Vincent S. had a pale quilted maple top and chose not to stain it. He covered it edge to edge in tattoo-style stickers instead. Here is how he layered, masked and coated it, and what to test before you try it.
