Thin Semi-Hollow Single-Cutaway Electric Guitar Kit, Mahogany Body, Pau Ferro Fretboard
SKU TEH-RMFC-463
Current price $239.99 USD
$239.99 USD - $239.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Nov 13 – Nov 27 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Build your own TE semi-hollow guitar with a mahogany body, black pickguard, and dual humbuckers. Classic tone meets DIY creativity.
  • Material: Mahogany (2 pcs, center-joint)
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Material: Pau Ferro
  • Nut: Ivory Plastic
  • Bridge: Hardtail
  • Semi-hollow body with single cutaway and one f-hole, routed under the pickguard (unfinished)
  • Black pickguard with a white line at the bevelled edge, fitted to the body and carrying two chrome-covered wide humbucker pickups with a single row of six pole screws each
  • Neck with dark fretboard, white pearloid dot inlays and fitted white nut
  • Chrome hardtail bridge with six adjustable saddles
  • Pre-wired control harness on a small circuit board with potentiometers, a toggle switch and a colored wiring loom
  • 2x chrome dome knobs
  • Black switch tip
  • 4x pot nuts and washers
  • Chrome curved jack plate with output jack socket
  • Coiled string set
  • Assorted screws
Thin Semi-Hollow Single-Cutaway Electric Guitar Kit, Mahogany Body, Pau Ferro Fretboard is in stock.
