Semi-Hollow PR w/ Solid Carved Maple Cap & Trapezoid Abalone Inlays
SKU PRH-RMOC-2
Original price $319.99 USD
$319.99 USD
$319.99 USD - $319.99 USD
Current price $319.99 USD
Semi-hollow PR Guitar Kit with F-holes Rosewood (Engineered) fretboard and beautiful trapezoid abalone inlays.
  • Straightforward wiring with few connections to solder, but the solid Maple Cap veneer is thin and easy to sand through, so use a light touch at the edges
  • Type: Semi-Hollow Chambered
  • Top Veneer: Solid Carved Maple Cap
  • Inlay Material: Abalone
  • Semi-hollow guitar body with two f-holes and a carved top, unfinished
  • Guitar neck with dark fretboard and abalone block inlays
  • 2x chrome-covered humbucker pickups in black mounting rings
  • Pre-wired control harness with potentiometers
  • 3-way toggle switch with black tip cap
  • Chrome square output jack plate with jack
  • Chrome stop bar tailpiece
  • Adjustable bridge
  • 2x tailpiece studs with knurled anchors
  • 2x bridge posts with knurled anchors
  • 2x black knurled knobs
  • Black control cavity cover
  • 2x strap buttons with felt washers and screws
  • Set of strings
  • Assorted chrome screws
  • Hex nuts and washers
Unfortunately, Semi-Hollow PR w/ Solid Carved Maple Cap & Trapezoid Abalone Inlays is out of stock.
