7-String Double-Cutaway Contoured Electric Guitar Kit, Basswood Body, Ebonized Fretboard
SKU RG7-RBPB-1
$289.99 USD
$289.99 USD - $289.99 USD
Current price $289.99 USD
Build your own 7-string basswood body kit guitar with ebonized fretboard and cool lightning bolt inlays.
  • Number of Strings: 7
  • Fixed bridge keeps the setup simple, with height and intonation adjusted at the individual saddles
  • Seven strings leave less margin at the nut and bridge, so check alignment before the final screw holes go in
  • Number of Frets: 24
  • Inlay Shape: Lightning Bolt
  • Shape: Styled
  • Nut: Black Plastic
  • Bridge: Hardtail
  • Finish: Black Finish
  • Basswood 7-string guitar body (unfinished)
  • Guitar neck with ebonized fretboard and white pearloid lightning bolt inlays (unfinished)
  • 2x black humbucker pickups with mounting rings and springs
  • Black 7-string fixed bridge
  • Black rear cavity covers
  • Wiring harness with potentiometers, 3-way toggle switch and black knobs
Unfortunately, 7-String Double-Cutaway Contoured Electric Guitar Kit, Basswood Body, Ebonized Fretboard is out of stock.
