Basswood EXP-style body Guitar Kit, Ebonized Fretboard
SKU EXP-RBEB-1
Original price $329.99 USD
Current price $299.99 USD
$299.99 USD - $299.99 USD
Build your own Basswood EXP-style Guitar with Ebonized Fretboard using our DIY Guitar Kits.
  • Controls: 1 Volume, 1 Tone, 3-Way
  • Angular-style guitar body (unfinished)
  • Guitar neck with ebonized fretboard and abalone pearloid block inlays (unfinished)
  • 2x black-covered humbucker pickups
  • Black adjustable bridge with posts and thumbwheels
  • Black knobs
  • Black neck plate with mounting screws
  • Black truss rod cover
  • Jack plate with output jack
  • Wiring harness with potentiometers and 3-way toggle switch
  • Set of guitar strings
Unfortunately, Basswood EXP-style body Guitar Kit, Ebonized Fretboard is out of stock.
