L1 Stripewood body Guitar Kit with Trapezoid White Pearloid Inlays
SKU LP-RZEB-1
Original price $289 USD
$289 USD
$289 USD - $289 USD
Current price $289 USD
  • Binding: Single Black
  • Tuners: Gold Sealed
  • Pickguard: 2-ply black
  • Finish: Gold
  • Stripewood guitar body, unfinished, routed for two humbuckers
  • Guitar neck with dark fretboard and white pearloid trapezoid inlays
  • 2x gold-covered humbucker pickups in black mounting rings
  • 3-way toggle switch with gold tip
  • Black toggle switch tip cap
  • Black Rhythm/Treble toggle ring washer
  • Gold output jack plate with output jack
  • Gold adjustable bridge
  • 2x gold bridge posts with knurled anchors
  • Gold stop bar tailpiece
  • 2x gold tailpiece studs with knurled anchors
  • 4x black numbered control knobs
  • Black pickguard with gold mounting bracket
  • Black round switch cavity cover
  • 2x gold strap buttons with black felt washers and screws
  • Set of strings
  • Assorted gold screws
  • Gold trim rings, hex nuts and washers
L1 Stripewood body Guitar Kit with Trapezoid White Pearloid Inlays is on pre-order.
