Thin Hollow Body Electric Guitar Kit, Venetian Cutaway, Flame Maple Veneer
SKU L3-RMRC-835
Original price $299 USD
Current price $269 USD
$269 USD - $269 USD
Build your own Thin Hollow Body Venetian Cutaway Guitar Kit with Rosewood Fretboard and Flame Maple Veneer using our DIY Guitar kits.
  • Material: Laminated Maple
  • Binding: Multi-ply Black
  • Inlay Shape: Split Parallelogram
  • Tuners: Sealed, Diecast, Chrome
  • Knobs: Black Plastic
  • Hollow body with flame maple veneer top, two f-holes and a bound edge
  • Neck with dark fretboard, frets and block inlays, and an unpainted headstock
  • 2x chrome-covered humbucker pickups with black mounting rings
  • Pre-wired harness with four pots and colored wiring
  • 3-way toggle switch with ivory tip, nut and washer
  • Black RHYTHM / TREBLE toggle washer ring
  • Chrome adjustable bridge with six saddles
  • Chrome stop bar tailpiece
  • 4x chrome posts and 2x thumbwheels for bridge and tailpiece
  • 4x black numbered knobs
  • Black truss rod cover with screw
  • Chrome L-shaped jack bracket with output jack
  • Coiled set of strings
Thin Hollow Body Electric Guitar Kit, Venetian Cutaway, Flame Maple Veneer is on pre-order.
Is the body solid wood?
No. The body is made of laminated wood, which is thin layers glued together. It has two f-holes and a thin flamed maple veneer on the top.
