SKU E25-RPBG-4812
Original price $319.99 USD
Current price $279.99 USD
$279.99 USD - $279.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Aug 3 – Aug 10 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Aug 24 – Sep 7 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Orientation: Right-Hand
  • Scale Length: 628mm / 24.7"
Intermediate (5/10)
  • Material: Maple Plywood
  • Type: Hollow
  • Body Binding: White
  • Upper Bout: 310mm
  • Lower Bout: 415mm
  • Waist: 250mm
  • Body Depth: 43.5mm
  • Center Block: Maple Wood Block Stabilizer (under bridge)
  • Material: Maple (2 pcs)
  • Joint: Set-neck
  • Radius: 12"
  • Inlay Shape: Diamond
  • Binding: White
  • Shape: Blues Classic 3+3
  • Tuner Holes: 10mm
  • Nut Width: 42mm
  • Bridge Pickup: None
  • Output Jack: Side-mounted
  • Bridge: Gold Floating Archtop Bridge (Rosewood Base)
  • Tailpiece: Gold Trapeze
  • Tuners: Sealed Diecast Gold
  • Knobs: Black Speed Knobs
  • Gold trapeze tailpiece
  • 2x black speed knobs
  • Gold output jack
  • Steel strings
