Basswood Body JG-style Guitar Kit with Maple Neck and Rosewood Fretboard
SKU JGS-RBRC-284
Original price $239.99 USD
Current price $229.99 USD
$229.99 USD - $229.99 USD
Build an offset electric guitar from a box of parts. This DIY kit gives you a basswood body, a bolt-on maple neck with a 21-fret rosewood fretboard, and three single coils you wire yourself. Basswood takes paint and solid colours well, so it is a forgiving first finish, and the vintage-style tremolo brings the classic offset shimmer once you set it up.
Intermediate (5/10)
  • Pickguard: Tortoise Pearloid
  • Cavity Covers: White
  • Offset basswood body (unfinished)
  • 3x single-coil pickups
  • White plastic nut
  • Tortoise pearloid pickguard
  • White back cavity cover
Unfortunately, Basswood Body JG-style Guitar Kit with Maple Neck and Rosewood Fretboard is out of stock.
