Hookline 7-String Pointed Single-Cutaway Electric Guitar Kit, Basswood Body, Bolt-On Maple Neck, 27-Inch Scale
SKU HKL1-RBAB-4246
Current price $259.99 USD
$259.99 USD - $259.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Sep 25 – Oct 9 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Number of Strings: 7
  • Material: Basswood (2-4 pcs)
  • Binding: Single Black
  • Material: Maple w/ a Skunk Stripe
  • Scale Length: 27 inches (685.8mm)
  • Binding: Ivory
  • Number of Frets: 24
  • Binding: Ivory
  • Nut: Bone (Real)
  • Unfinished pointed single-cutaway body with body binding, routed for two humbuckers and a rear control cavity
  • Maple neck with maple fingerboard, side dot markers and a drilled headstock
  • 7x black sealed tuners
  • 2x black open humbucker pickups with adjustable pole screws in black mounting frames
  • 1x pre-wired control harness with potentiometers and hookup wire
  • 1x three-way toggle switch with black tip
  • 4x chrome dome knobs
  • 1x black bridge with seven adjustable saddles
  • 1x black stop tailpiece bar
  • 2x black bridge posts and 2 black bushings
  • 1x black neck plate
  • 4x long black neck mounting screws
  • 1x black plastic control cavity cover
  • 1x black truss rod cover
  • 1x set of chrome washers, nuts and lock rings
  • 2x bags of small black hardware parts
  • 2x black strap buttons
  • 1x Allen wrench
Hookline 7-String Pointed Single-Cutaway Electric Guitar Kit, Basswood Body, Bolt-On Maple Neck, 27-Inch Scale is in stock.
