Singlecut Junior Solid-Body Guitar Kit with Spalted Maple Veneer
SKU LPJ1-RMRC-1
Original price $289 USD
Current price $239 USD
$239 USD - $239 USD
Build your own junior solid-body singlecut guitar using this DIY guitar kit with a beautiful Spalted Maple Veneer, mahogany body & bolt-on maple neck, Rosewood fretboard, and trapezoid white pearloid fretboard inlays.
  • Neck Pickup: None
  • Bridge Pickup: P90
  • Body with spalted maple veneer top, unfinished
  • Neck with dark fretboard and white pearloid trapezoid inlays, unfinished
  • Black soapbar single-coil pickup
  • Chrome wraparound bridge with two mounting studs and bushings
  • Pre-wired wiring harness with two potentiometers and capacitor
  • Black truss rod cover
  • Black plastic cavity cover plate
  • 2x black knobs
  • Set of strings
  • Truss rod adjustment wrench
Singlecut Junior Solid-Body Guitar Kit with Spalted Maple Veneer is in stock.
1 P90, 1 volume, 1 tone
It has a one-piece wraparound bridge on two studs. The strings attach to the bridge itself, so there is no separate tailpiece. There is no tremolo arm.
It has one P90 pickup at the bridge, with one volume and one tone control.
