SKU E25-RPBG-4812
Original price $319.99 USD
Current price $279.99 USD
$279.99 USD - $279.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Sep 10 – Sep 17 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Oct 1 – Oct 15 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Intermediate (5/10)
  • Material: Maple Plywood
  • Binding: White
  • Body Depth: 43.5mm
  • Upper Bout: 310mm
  • Waist: 250mm
  • Lower Bout: 415mm
  • Joint: Set-neck
  • Scale Length: 628mm / 24.7"
  • Inlay Shape: Diamond
  • Binding: White
  • Nut Width: 42mm
  • Tuner Holes: 10mm
  • Bridge Pickup: None
  • Bridge: Gold Floating Archtop Bridge (Rosewood Base)
  • Tailpiece: Gold Trapeze
  • Tuners: Sealed Diecast Gold
  • Knobs: Black Speed Knobs
  • Finish: Gold
  • Gold trapeze tailpiece
  • 2x black speed knobs
  • Gold output jack
  • Steel strings
1 humbucker, 1 volume, 1 tone
