Mahogany NI Guitar Kit with 2 Humbuckers, Black Finish Hardware
SKU NI-RMEB-4730
Original price $259.99 USD
$259.99 USD
$259.99 USD - $259.99 USD
Current price $259.99 USD
Build your own Mahogany NI-style Guitar with with 2 Humbuckers and Black Finish Hardware.
  • Number of Frets: 24
  • Nut: Locking Nut
  • Middle Pickup: None
  • Controls: 2 Volume, 2 tone, 3-way Toggle
  • Bridge: Locking Tremolo
  • Tuners: Sealed
  • Unfinished mahogany body routed for two humbuckers, a locking vibrato and a rear control cavity
  • Neck with dark fretboard, dot position markers, a drilled headstock and a black locking clamp at the nut
  • 1x black truss rod cover with two screws
  • 1x black oval jack plate
  • 1x black output jack with nut and washer
  • 1x black rear cavity cover with a slot
  • 1x large black backplate
  • 2x black strap buttons with washers
  • 2x black open-pole humbuckers in black mounting frames
  • 1x wiring harness with two pots, a toggle switch, wires, nuts and washers
  • 1x black locking vibrato bridge with six saddles
  • 1x black vibrato arm
  • 3x vibrato springs with claw and mounting screws
  • 4x black knobs
  • 4x long black neck mounting screws
  • 4x black washers
  • 1x bag of assorted black screws
  • 1x guitar cable with two angled plugs
Unfortunately, Mahogany NI Guitar Kit with 2 Humbuckers, Black Finish Hardware is out of stock.
