SKU EXP-RZZB-1
Current price $239.99 USD
$239.99 USD - $239.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Oct 2 – Oct 9 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
  • Nut: Black Plastic
  • Tuners: Black Sealed
  • Black stop tailpiece
  • Black truss rod cover
  • 3x black knurled knobs
Zebrawood EXP-style Guitar Kit with Trapezoid Fretboard Inlays is on pre-order.
