Wide Neck Hollow Body Electric Guitar Kit with 48 mm Nut for Big Hands, Maple Body, Rosewood Fretboard, Single Humbucker
SKU E75-RSSC-5104
Original price $279 USD
Current price $254 USD
$254 USD - $254 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Nov 16 – Nov 23 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
  • Secure, encrypted checkout.
A wide neck made for big hands. The nut is 48 mm wide, where a standard 6-string kit neck is about 42 mm, so the strings sit further apart and thick fingertips have room on every fret. The neck has a full U-profile, which fills the palm instead of thinning out under it. If chords feel cramped on a regular neck, this is the kit built for you.
Around that neck: a fully hollow maple body with two f-holes and multi-ply binding, a set-in maple neck with a bound rosewood fretboard and abalone pearloid trapezoid inlays, a bone nut, one chrome-covered neck humbucker, a floating bridge and a chrome trapeze tailpiece. One pickup and two knobs keep the wiring simple.
  • Binding: Multi-ply Ivory (top and back)
  • Top: None
  • Profile: U-shaped
  • Shape: Classic Blues, 3+3
  • Nut: Bone (pre-installed)
  • Nut Width: 48 mm
  • Bridge Pickup: None
  • Tailpiece: Trapeze
  • Tuners: Sealed
  • Unfinished fully hollow maple body with two f-holes, multi-ply binding, a routed neck pickup cavity, two control holes, a side jack hole and a routed neck pocket
  • Unfinished maple neck with a bound rosewood fretboard, abalone pearloid trapezoid inlays, a pre-installed 48 mm bone nut and a drilled 3+3 headstock
  • 1x chrome-covered humbucker with mounting ring and screws
  • 1x wiring harness with volume and tone pots and output jack
  • 2x chrome knobs
  • 1x black truss rod cover with screws
  • 1x Allen wrench
  • 1x guitar cable
Compare it with our X-braced hollow body kit, or browse the full range of hollow body guitar kits.
Wide Neck Hollow Body Electric Guitar Kit with 48 mm Nut for Big Hands, Maple Body, Rosewood Fretboard, Single Humbucker is in stock.
1 humbucker, 1 volume, 1 tone
How wide is the neck on this kit?
The nut is 48 mm wide. Most 6-string guitar kits use a nut of about 42 mm, so this neck gives every string a little more room, which helps players with large hands or thick fingertips.
Is it a 6-string or a 7-string guitar?
It is a 6-string guitar. The neck is as wide as many 7-string necks at the nut, but it is drilled for 6 tuners in a 3+3 layout and takes standard 6-string electric guitar strings.
What is a U-profile neck?
U-profile describes the shape of the back of the neck. It is rounder and fuller than the common C-shape, so it fills the palm, which many players with big hands find more comfortable.
