Semi-Hollow ST style guitar kit w/ Mahogany body, Maple Neck
SKU STH-RYBC-1
Original price $279 USD
Current price $259 USD
$259 USD - $259 USD
  • Material: Mahogany (1 pc)
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Cavity Covers: White
  • Mahogany semi-hollow guitar body (unfinished) with an f-hole and open pickup and control routes
  • Maple neck with dark fretboard and white dot inlays
  • 6x chrome sealed tuners
  • 6x chrome tuner bushings
  • 6x washers
  • Set of guitar strings
  • 2x black pickups with six pole pieces, in black mounting rings
  • Chrome neck plate with gasket and four long mounting screws
  • Chrome rounded-end cover plate with screw holes at each end
  • 2x chrome dome knobs
Semi-Hollow ST style guitar kit w/ Mahogany body, Maple Neck is on pre-order.
