SKU HKL1-RMRG-2
Original price $259 USD
Current price $229 USD
$229 USD - $229 USD
A set-in-neck DIY guitar kit built on our Hookline body: a pointed single-cutaway whose lower bout sweeps into a downward hook. Solid mahogany body and mahogany neck, a bound rosewood fretboard with white pearloid parallelogram inlays, multi-ply ivory body binding and a full gold hardware set. The electronics ship loose rather than pre-wired, so this build includes soldering.
  • Open-grain mahogany benefits from grain filling before the color coats
  • Binding: Ivory
  • Inlay Shape: Parallelogram
  • Side Dots: Yes
  • Nut Width: 43 mm
  • Tuner Layout: 3+3
  • Tuners: Sealed diecast, 3+3
  • Knobs: Amber bell knobs
  • Truss Rod Cover: Black bell
  • Finish: Gold
  • 4x amber bell knobs
  • Black bell truss rod cover
  • 2x gold strap buttons
  • Steel strings
Does the body have binding?
Yes. The top edge of the body has multi-ply ivory binding. The back edge has none.
