SKU HKL1-RMRG-3
Original price $299 USD
Current price $259 USD
$259 USD - $259 USD
A set-in-neck DIY guitar kit built on our Hookline body, a pointed single-cutaway whose lower bout sweeps into a downward hook, topped with a flame maple veneer. Solid mahogany body and mahogany neck, a bound rosewood fretboard with white pearloid parallelogram inlays, multi-ply ivory body binding and a full gold hardware set. The veneer takes a translucent stain or burst beautifully. The electronics ship loose rather than pre-wired, so this build includes soldering.
  • The flame maple veneer is thin, so sand lightly and never power-sand the top, or you will cut through the figure
  • Top: Flamed maple veneer on the front (thin sheet, about 0.5 mm); plain mahogany back
  • Binding: Ivory
  • Inlay Shape: Parallelogram
  • Side Dots: Yes
  • Nut Width: 43 mm
  • Tuner Layout: 3+3
  • Tuners: Sealed diecast, 3+3
  • Knobs: Amber bell knobs
  • Truss Rod Cover: Black bell
  • Finish: Gold
  • Mahogany guitar body (unfinished) with flame maple veneer top and multi-ply ivory binding
  • 4x amber bell knobs
  • Black bell truss rod cover
  • 2x gold strap buttons
  • Steel strings
Hookline Single-Cutaway Electric Guitar Kit, Flame Maple Veneer, Mahogany Body, Set-In Mahogany Neck, Rosewood Fretboard, Gold Hardware is in stock.
Is the top solid flamed maple?
No. The top is a thin flamed maple veneer glued onto the body. Sand it lightly so you do not sand through it.
