Hollow Body Archtop Electric Guitar Kit, Venetian Cutaway, Spalted Maple Veneer, Ebonized Fretboard
SKU L5-RPEC-798
Original price $309 USD
Original price $309 USD - Original price $309 USD
Current price $299 USD
$299 USD - $299 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Dec 1 – Dec 8 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
Build your own Hollow Body Venetian Cutaway Guitar Kit with Ebonized Fretboard and Spalted Maple Veneer using our DIY Guitar kits.
  • Material: Laminated Maple
  • Cutaway: Single (Venetian)
  • Binding: Multi-ply Ivory
  • Upper Bout: 310 mm
  • Waist: 250 mm
  • Lower Bout: 415 mm
  • Depth: 83 mm
  • Inlay Shape: Fangs
  • Shape: Semi-styled, 3+3
  • Nut: Black Plastic
  • Hollow archtop guitar body with a single rounded cutaway, spalted figured top veneer, two f-holes and multi-ply ivory body binding, routed for two humbuckers (unfinished)
  • Neck with dark fretboard and abalone pearloid fang inlays
  • 6x chrome sealed tuners with metal buttons, bushings, washers and mounting screws
  • 2x humbucker pickups with chrome covers in black mounting rings
  • Black bridge with six adjustable saddles, plus two chrome posts and thumbwheels
  • Chrome hinged vibrato tailpiece with spring, arm and black insert plate
  • Pre-wired potentiometers and 3-way toggle switch with a cloth-covered wiring loom
  • 4x black knurled knobs
  • Black round switch washer
  • Coiled string set
  • Assorted screws, nuts and washers
Hollow Body Archtop Electric Guitar Kit, Venetian Cutaway, Spalted Maple Veneer, Ebonized Fretboard is in stock.
