Hollow Body Archtop Electric Guitar Kit, Spalted Maple Veneer, Chrome Hardware
SKU E175-RMEC-1
Original price $309 USD
Original price $309 USD - Original price $309 USD
Current price $299 USD
$299 USD - $299 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Dec 2 – Dec 9 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
Build your own E75 hollow body guitar with Mahogany Body and Neck, Spalted Maple veneer, F-Holes, and Florentine-style single cutaway.
  • Material: Laminated Maple
  • Cutaway: Florentine-style Single
  • Binding: Black & White Multi-ply
  • Width at 5th Fret: 46 mm
  • Width at 9th Fret: 49 mm
  • Width at 12th Fret: 52 mm
  • Width at 22nd Fret: 56 mm
  • Shape: Semi-styled, 3+3
  • Controls: 2 Volume, 2 Tone, 3 Way Switch
  • Unfinished hollow body with two f-holes, figured veneer top and bound edge
  • Unfinished neck with dark fretboard and white pearloid block inlays
  • String set
  • Output jack with nut and washer
  • 2x chrome-covered humbucker pickups in black mounting rings
  • Chrome trapeze tailpiece
  • Chrome bridge with individual saddles
  • 2x chrome bridge posts and thumbwheels
  • 4x black knobs
  • Black pickguard with chrome mounting bracket
  • Assorted chrome screws
Hollow Body Archtop Electric Guitar Kit, Spalted Maple Veneer, Chrome Hardware is in stock.
Is the body solid wood?
No. It is a hollow body made of laminated wood, which is thin layers glued together. The top has a thin spalted maple veneer and two f-holes.
It has an adjustable bridge that stands on two posts, and a separate trapeze tailpiece. The tailpiece holds the string ends at the bottom of the body.
