Thin Semi-Hollow Single-Cutaway Electric Guitar Kit, Mahogany Body, Quilted Maple Veneer, String-Through Body
SKU TEH-RMRC-1
$269 USD
$269 USD - $269 USD
Current price $269 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. Pre-order Est. Delivery: ~3 months This kit is currently in production with inventory on the way. Estimated delivery is approximately 3 months, including shipping time. Free Shipping
Semi-Hollow TE-style Guitar Kit with Mahogany Body, Quilt Maple body veneer, and Maple neck.
  • Straightforward wiring with few connections to solder, but the quilted Maple veneer is thin and easy to sand through, so use a light touch at the edges
  • Material: Mahogany (2 pcs, center joined)
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Wiring Diagram: 1 Volume, 1 Tone, 3-Way Switch
  • Bridge: String-Through Body
  • Pickguard: Black Pearloid
  • Semi-hollow body with f-hole, unfinished, with black pearloid pickguard and two chrome-covered humbuckers already fitted
  • Neck with dark fretboard and white dot inlays, unfinished
  • Chrome six-saddle string-through bridge with mounting screws
  • 6x chrome string ferrules
  • Pre-wired wiring harness with 3-way lever switch and potentiometer
  • 2x chrome dome knobs
  • 2x chrome strap buttons with screws
  • Set of strings
  • Truss rod adjustment wrench
Thin Semi-Hollow Single-Cutaway Electric Guitar Kit, Mahogany Body, Quilted Maple Veneer, String-Through Body is on pre-order.
It has a fixed bridge with six saddles. The strings go in from the back of the body and come out through the bridge. There is no tremolo arm.
Is the body hollow or solid?
