Stripewood EXP-style Guitar Kit with Trapezoid Fretboard Inlays
SKU EXP-RZZB-1
Original price $289 USD
Current price $239 USD
$239 USD - $239 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Nov 17 – Nov 24 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
  • Secure, encrypted checkout.
Build your own DIY guitar kit with Stripewood body & neck, trapezoid inlays, and black pickguard and hardware.
  • Nut: Black Plastic
  • Tuners: Black Sealed
  • Black stop tailpiece
  • Black truss rod cover
  • 3x black knurled knobs
Stripewood EXP-style Guitar Kit with Trapezoid Fretboard Inlays is on pre-order.
