SKU DVHB-RPRB-4237
Original price $299 USD
$299 USD
$299 USD - $299 USD
Current price $299 USD
  • Number of Strings: 4
  • Material: Mahogany (2 pcs)
  • Scale Length: 775 mm / 30.5" (short scale)
  • Radius: 12" / 305 mm
  • Number of Frets: 19
  • Shape: Blues Classic 2+2
  • Tuners: Closed, Chrome
  • 2x humbucker pickups
  • Output jack and jack plate
  • 4x chrome control knobs
