Stripewood EXP-style Guitar Kit
SKU EXP-RZZB-2
Original price $299 USD
Current price $269 USD
$269 USD - $269 USD
Build your own DIY guitar kit with Stripewood body & neck, trapezoid inlays, and white pickguard and hardware.
  • Nut: Black Plastic
  • Tuners: Black Sealed
  • Black stop tailpiece
  • White pickguard
  • Black truss rod cover
  • 3x black knurled knobs
  • Coil of green hookup wire
Unfortunately, Stripewood EXP-style Guitar Kit is out of stock.
