SKU JG-RMRC-1
Original price $279.99 USD
Current price $229.99 USD
$229.99 USD - $229.99 USD
  • Adjustable bridge
  • White plastic nut
  • Red tortoise pickguard
  • 2x black control knobs
Short-scale JG style Guitar Kit with Mahogany Body, Rosewood Fretboard is on pre-order.
