JM Guitar Kit with Mahogany Body, Maple Neck
SKU JM-RMRC-1
$269.99 USD
$269.99 USD - $269.99 USD
Current price $269.99 USD
Build a full-scale offset electric guitar from a box of parts. This DIY kit gives you a solid mahogany body, a bolt-on maple neck with a 21-fret rosewood fretboard and pearl dot inlays, and three single coils you wire yourself. The vintage-style tremolo brings the classic offset shimmer once you set it up.
Intermediate (5/10)
  • Controls: 1 Volume, 2 Tone, 5-Way selector
  • Wiring Diagram: 1 Volume, 2 Tone, 5-Way Selector
  • Bridge: Vintage-style Tremolo (with arm)
  • Tuners: Sealed (6-in-line)
  • Pickguard: Tortoise
  • Cavity Covers: Tortoise
  • 3x single-coil pickups
  • 6x sealed tuners with mounting hardware
  • Tortoise pickguard
  • Tortoise back cavity cover
JM Guitar Kit with Mahogany Body, Maple Neck is on pre-order.
