F2 Guitar Kit w/ Mahogany Body & Neck, Trapezoid Abalone Pearloid Inlays
SKU FB-RMBB-1
Original price $279.99 USD
Current price $239.99 USD
$239.99 USD - $239.99 USD
Build an offset-body electric guitar with a reverse headstock. All six tuners sit on one side.
The middle of the body is a raised strip that holds the pickups. The sides step down from it.
The kit is unfinished mahogany, so you pick the color and the finish. The neck bolts on with four bolts. You need no glue and no clamps. Every cavity and hole is already cut, so you need no routing.
Two humbuckers and a 3-way switch let you play the neck pickup, the bridge pickup, or both. Each pickup has its own volume and tone knob. You solder the electronics. You learn how a pickup, a switch and a knob work together.
  • Mahogany body and neck
  • Ebonized fretboard, 22 stainless steel frets, trapezoid abalone pearloid inlays
  • 628 mm / 24.75″ scale, bone nut, sealed tuners
  • Adjustable bridge with stopbar tailpiece
  • Pre-wired control harness, pickguard, strap buttons and cable included
  • Top Contour: Raised center strip (the pickup section stands above the side wings)
  • Shape: Reverse, 6-in-line (all six tuners on one side)
  • Unfinished guitar body
  • Unfinished neck with ebonized fretboard and trapezoid abalone pearloid inlays
  • String set
  • Black stop tailpiece
  • Black bridge with individual saddles
  • 4x black bridge and tailpiece posts
  • Black neck plate with 4 neck bolts
  • Black control-cavity cover plate
  • 4x black dome control knobs
  • Pickguard
  • 2x black strap buttons with screws
  • Assorted black screws
No woodworking or routing required. All cavities, holes, and channels are pre-cut.
F2 Guitar Kit w/ Mahogany Body & Neck, Trapezoid Abalone Pearloid Inlays is in stock.
