SKU JMB-RMEC-3476
Current price $279.99 USD
$279.99 USD - $279.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Oct 8 – Oct 22 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Build a 34-inch offset bass from a box of parts. This DIY kit gives you a solid mahogany body, a bolt-on maple neck with a 20-fret fretboard and pearl dot inlays, and two J-style single-coil pickups you wire yourself. The fixed bridge keeps the setup straightforward, which makes this one of the easier kits to get playing.
  • Number of Strings: 4
Beginner (3/10)
  • Material: Mahogany (2 pcs)
  • Scale Length: 864 mm / 34"
  • Radius: 12" / 305mm
  • Number of Frets: 20
  • Controls: 2 Volume, 1 Tone
  • Bridge: Fixed
  • Tuners: Sealed (4-in-line)
  • Pickguard: Ivory
  • Fixed bass bridge
  • White plastic nut
  • Ivory pickguard
  • Bass cable
