Double-Cutaway Semi-Hollow Electric Guitar Kit, Alder Body, Quilted Maple Veneer
SKU STH-RARC-0510
Original price $259.99 USD
Current price $233.99 USD
$233.99 USD - $233.99 USD
Build Your Own Alder Body Semi-hollow S-style Guitar Kit with Quilted Maple Veneer using our DIY Guitar Kits.
  • Material: Alder
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Binding: Single White
  • Pickguard: Pearl White
  • Knobs: White
  • Cavity Covers: White
  • Neck with fretted fingerboard, dot position markers and a drilled headstock
  • 1x pearl-white pickguard with three white single-coil pickups, three white skirted knobs and a white switch tip installed
  • 1x chrome vibrato bridge with six saddles and a steel block
  • 1x chrome vibrato arm
  • 1x tremolo spring claw with three springs and two mounting screws
  • 1x pearl-white tremolo backplate with string slot
  • 1x chrome neck plate with four screws
  • Assorted chrome mounting screws
Double-Cutaway Semi-Hollow Electric Guitar Kit, Alder Body, Quilted Maple Veneer is on pre-order.
