SKU E25-RPBG-4812
Original price $319.99 USD
Current price $279.99 USD
$279.99 USD - $279.99 USD
Intermediate (5/10)
  • Material: Maple Plywood
  • Binding: White
  • Body Depth: 43.5mm
  • Upper Bout: 310mm
  • Waist: 250mm
  • Lower Bout: 415mm
  • Joint: Set-neck
  • Scale Length: 628mm / 24.7"
  • Inlay Shape: Diamond
  • Binding: White
  • Nut Width: 42mm
  • Tuner Holes: 10mm
  • Bridge Pickup: None
  • Tailpiece: Gold Trapeze
  • Tuners: Sealed Diecast Gold
  • Knobs: Black Speed Knobs
  • Finish: Gold
  • Gold trapeze tailpiece
  • 2x black speed knobs
  • Gold output jack
  • Steel strings
1 humbucker, 1 volume, 1 tone
