L1 Basswood body Guitar Kit with Maple Fretboard
SKU LP-RBPB-1
Original price $299 USD
Current price $259 USD
$259 USD - $259 USD
Build your own Basswood LP-style body Guitar with Maple Fretboard using our DIY Guitar kits.
  • Binding: Single Black
  • Inlay Shape: Block
  • Single-cutaway guitar body with figured top, unfinished, routed for two humbuckers
  • Maple neck with maple fretboard and black block inlays
  • Wiring harness with four potentiometers
  • Black stop bar tailpiece
  • 4x black posts and bushings for the bridge and tailpiece
  • 4x black knurled dome knobs
  • Output jack on a square black jack plate
  • Black pickguard mounting bracket with screw
  • Black round switch cavity cover
  • Black toggle switch washer with rhythm and treble lettering
L1 Basswood body Guitar Kit with Maple Fretboard is on pre-order.
