Bound Neck and Headstock Single-Cutaway Electric Guitar Kit, Mahogany Body, Rosewood Fretboard, Humbuckers, Vinework Inlay
SKU LP-RMRC-5042
Original price $279 USD
Current price $229 USD
$229 USD - $229 USD
Ivory binding runs along both fretboard edges, around the headstock face and around the top and back of the body on this single-cutaway kit, so the trim is already in place before you finish the wood. An Abalone Pearloid Vinework inlay climbs the full length of the bound rosewood fretboard: one continuous inlay from the first fret to the upper frets, factory-installed in the board.
Underneath the trim it is a set-neck single-cutaway build: a mahogany body with no veneer, a mahogany neck that glues into a long neck pocket, 22 stainless steel frets, two chrome-covered humbuckers in ivory rings, an adjustable bridge with a stopbar tailpiece, and an ivory pickguard and cavity covers to match the binding.
  • Body, neck and headstock binding should be masked or scraped clean after staining so the ivory edge stays crisp
  • Binding: Multi-ply Ivory (top and back edges)
  • Inlay Shape: Vinework
  • Side Dots: Black
  • Shape: Classic Blues, 3+3
  • Nut: Ivory Plastic (pre-installed)
  • Pickguard: Ivory
  • Knobs: Chrome dome
  • Cavity Covers: Ivory
  • Truss Rod Cover: Black
  • 1x unfinished mahogany single-cutaway body with multi-ply ivory binding, routed for two humbuckers
  • 1x mahogany set neck with bound rosewood fretboard, Vinework inlay, bound headstock and pre-installed nut
  • 2x chrome-covered humbuckers in ivory mounting rings
  • 4x chrome dome knobs with nuts and washers
  • 1x chrome stopbar tailpiece with 2 studs
  • 1x large ivory control cavity cover
  • 1x black truss rod cover
  • 1x bag of assorted screws
  • 1x Allen wrench
Browse the full range of single-cutaway guitar kits, or compare the plain mahogany set-neck kit with dot inlays and the mahogany kit with P90 pickups.
Unfortunately, Bound Neck and Headstock Single-Cutaway Electric Guitar Kit, Mahogany Body, Rosewood Fretboard, Humbuckers, Vinework Inlay is out of stock.
What is the Vinework inlay made of?
It is Abalone Pearloid, a man-made material that looks like abalone shell. The vine is one continuous inlay set into the rosewood fretboard at the factory, so there is nothing to install.
It adds ivory binding on the fretboard edges, the headstock and the top and back of the body, plus the Vinework inlay. The mahogany set-neck kit has dot inlays and no binding, and the P90 kit uses P90 pickups and trapezoid inlays.
It is rated Intermediate, 7 out of 10. The neck is glued in, the mahogany needs grain filling, and the binding should be masked or scraped after staining. See how we score every kit in our build difficulty guide.
What tuners fit the headstock?
The headstock is drilled with 10 mm holes in a 3+3 layout, which fits modern sealed tuners. The kit already includes six chrome sealed tuners.
