Double-Cutaway Contoured Electric Guitar Kit, Stripewood Body, Chrome Hardware, Left-Handed
SKU ST-LZZC-1
Current price $259.99 USD
$259.99 USD - $259.99 USD
Build your own left-handed DIY guitar with this beautiful Stripewood ST style kit.
Stripewood is our name for this wood. The factory dyes thin sheets of wood, glues them into a block, and shapes it. So the stripes run all the way through, not only on top. Other shops sell it as engineered zebrawood. Want to stain or oil it? Test inside a cavity first.
You can find ST-style guitar building instructions here: ST Guitar Kit Assembly Manual.
  • Dexterity: Left-Handed
  • Knobs: White
  • Cavity Covers: White
  • Neck plate with screws
  • Output jack with wiring
  • String trees
Double-Cutaway Contoured Electric Guitar Kit, Stripewood Body, Chrome Hardware, Left-Handed is on pre-order.
