Hollow Body Archtop Electric Guitar Kit, Flame Maple Veneer, Maple Body, Rosewood Fretboard
SKU E175-RPRC-1
Original price $319 USD
Current price $279 USD
$279 USD - $279 USD
Build your own E75-style hollow body guitar with Mahogany Neck, Flame Maple veneer, F-Holes, and Florentine-style single cutaway.
  • Material: Laminated Maple
  • Cutaway: Florentine-style Single
  • Width at 5th Fret: 46 mm
  • Width at 9th Fret: 49 mm
  • Width at 12th Fret: 52 mm
  • Width at 22nd Fret: 56 mm
  • Inlay Shape: Split Parallelogram
  • Shape: Classic Blues, 3+3
  • Hollow guitar body with two f-holes (unfinished)
  • Guitar neck with dark fretboard and white pearloid split parallelogram inlays
  • 6x chrome closed tuners with olive-green tulip buttons, plus bushings and washers
  • 2x humbucker pickups with chrome covers
  • Wiring harness with four potentiometers
  • 4x chrome dome knobs
  • Chrome trapeze tailpiece
  • Adjustable bridge with six saddles on a curved wooden base
  • Set of guitar strings
  • Nuts and washers
Hollow Body Archtop Electric Guitar Kit, Flame Maple Veneer, Maple Body, Rosewood Fretboard is in stock.
Is the body solid wood?
No. It is a hollow body made of laminated wood, which is thin layers glued together. The top has a thin flamed maple veneer and two f-holes.
