Block-Inlay Slingback Offset Bass Guitar Kit with Paddle Headstock, Mahogany Body, Maple Fretboard, 2 Single-Coil Pickups
SKU JMB-RMSC-5118
Original price $269 USD
Current price $224 USD
$224 USD - $224 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Dec 2 – Dec 9 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
Black block inlays set into a pale maple fretboard. Every marker on this neck is a solid black square, from the first fret up to the nineteenth, so the fretboard reads clearly from across a stage and looks bold even before you add any finish. The headstock comes as a plain tapered paddle with the four tuner holes already drilled: play it as it is, or cut it to an outline of your own.
Underneath is a solid mahogany offset body with a white pickguard, a 34-inch scale mahogany neck that screws onto the body, two single-coil bass pickups on a chrome control plate (two volumes and one tone), a four-saddle chrome bridge and open-gear chrome tuners.
  • Number of Strings: 4
  • Mahogany has open grain, so it needs grain filler before a smooth finish
  • The paddle headstock is playable as shipped; cutting your own outline is optional extra work
  • Fixed four-saddle bridge with pre-drilled mounting keeps setup simple
  • Top: None
  • Scale Length: 864 mm / 34"
  • Radius: 12" / 305 mm
  • Number of Frets: 20
  • Inlay Shape: Block (9 markers, frets 1, 3, 5, 7, 9, 12, 15, 17 and 19)
  • Shape: Blank paddle, 4-in-line (tapered, uncut outline)
  • Neck Pickup: J-style Single Coil
  • Bridge Pickup: J-style Single Coil
  • Controls: 2 Volume, 1 Tone
  • Output Jack: Top jack (on the control plate)
  • Bridge: Fixed 4-saddle bass bridge
  • Tuners: Open-gear, 4-in-line
  • Knobs: Chrome dome
  • Cavity Covers: None (controls mount on the top control plate)
  • 1x Mahogany bass body (unfinished) with white pickguard fitted
  • 1x Mahogany bass neck with maple fretboard and black block inlays (unfinished)
  • 4x Chrome open-gear bass tuners with bushings and screws
  • 2x Black single-coil bass pickups with mounting screws and springs
  • 1x Chrome 4-saddle bass bridge with mounting screws
  • 1x Chrome control plate with 2 volume and 1 tone pots, knobs and output jack
  • 1x Chrome neck plate with 4 neck screws
  • 1x Set of steel bass strings
  • 1x String retainer
  • 2x Strap buttons with felt washers
  • 1x Instrument cable
  • Optional, to reshape the headstock: Coping saw or jigsaw, rasp or files, sandpaper
No routing required - all body cavities, holes, and channels are pre-cut. The headstock outline is the only part you can shape yourself, and that is optional.
See the other basses in this line: the mahogany offset bass kit with a rosewood fretboard and the left-handed offset bass kit with an ebonized fretboard, or browse all bass guitar kits.
Block-Inlay Slingback Offset Bass Guitar Kit with Paddle Headstock, Mahogany Body, Maple Fretboard, 2 Single-Coil Pickups is in stock.
What makes the fretboard on this bass kit different?
The neck has a pale maple fretboard with solid black block inlays at frets 1, 3, 5, 7, 9, 12, 15, 17 and 19. The markers are black plastic, set flush into the maple, so they stay easy to read and need no extra work from you.
Do I have to cut the headstock myself?
No. The headstock ships as a plain tapered paddle with the four tuner holes already drilled, so you can finish and play it as it is. If you want a different outline, you can cut and sand it to your own design, keeping clear of the tuner holes.
How is this kit different from your other offset bass kits?
It shares the offset body outline, the 34-inch scale and the two single-coil pickups with our mahogany offset bass kit and the left-handed version. This one adds a maple fretboard with black block inlays, a paddle headstock, a bone nut and chrome open-gear tuners.
How hard is it to build?
We rate it Beginner, 3 out of 10. The mahogany body needs grain filler before a smooth finish, and the pickups and controls need soldering; everything else is pre-cut and pre-drilled. See how we score kits in our build difficulty guide.
