Hollow Body Archtop 7-String Electric Guitar Kit, Single Florentine Cutaway
SKU E175-RMPB-7
Original price $329 USD
Current price $299 USD
$299 USD - $299 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Dec 5 – Dec 19 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Build your own 7-string hollow guitar kit with a mahogany body, ebonized fretboard, F-holes, and Florentine-style single cutaway.
  • Number of Strings: 7
  • Binding: Single White
  • Width at 5th Fret: 54 mm
  • Width at 9th Fret: 56 mm
  • Width at 22nd Fret: 64 mm
  • Inlay Shape: Block
  • Shape: Classic Blues
  • Nut Width: 47 mm
  • Tuners: Sealed
  • Hollow archtop guitar body with two f-holes, unfinished
  • Guitar neck with dark fretboard and abalone pearloid block inlays
  • 2x black-covered humbucker pickups with seven pole pieces per row
  • Black adjustable bridge
  • 2x black bridge posts with anchors
  • Black stop bar tailpiece
  • 2x black tailpiece studs with anchors
  • 4x black knurled domed knobs
  • Black archtop pickguard with black mounting bracket
  • Set of strings
  • Assorted black screws
  • Hex nuts, washers and trim rings
Hollow Body Archtop 7-String Electric Guitar Kit, Single Florentine Cutaway is in stock.
How many strings does it have?
It has seven strings. The two humbuckers and the bridge are made for seven strings.
It has two parts. An adjustable bridge with seven saddles sits in front of a separate stop tailpiece. The tailpiece holds the string ends. There is no tremolo arm.
