Double-Cutaway Contoured Electric Guitar Kit, Stripewood Body, Rosewood Fretboard, Black Hardware
SKU ST-RZEB-1
Original price $289 USD
Current price $239 USD
$239 USD - $239 USD
Ready to add a new badge to your DIY hall of fame? Our Stripewood ST style body Guitar kit with a Rosewood fretboard is ready to roll with you. Put your craftsmanship to the test and create your very own right-handed guitar, featuring a bolt-on neck and 22 frets. It's practically a symphony of wood, eagerly waiting to play your tune. Time to pull out those tools and let the music begin!
Stripewood is our name for this wood. The factory dyes thin sheets of wood, glues them into a block, and shapes it. So the stripes run all the way through, not only on top. Other shops sell it as engineered zebrawood. Want to stain or oil it? Test inside a cavity first.
  • Striped engineered-wood guitar body, double-cutaway and contoured, with a black pickguard already fitted
  • Black pickguard assembly with three black single-coil pickups, three black numbered knobs, a blade selector switch and wiring
  • Neck with rosewood fretboard (frets installed) and dot inlays
  • Black tremolo bridge with six saddles and a sustain block
  • Black tremolo arm
  • Tremolo spring claw with two mounting screws
  • 3x springs
  • Black back cover plate with six string slots
  • Black rectangular back cover plate
  • Black boat-shaped jack plate with output jack fitted
  • 2x black strap buttons
Double-Cutaway Contoured Electric Guitar Kit, Stripewood Body, Rosewood Fretboard, Black Hardware is in stock.
